Windows 11 Support Center. -
- HP Community
- Printers
- Printer error , "there is a problem with supply system". Car...
1 REPLY 1
07-13-2024 02:00 PM
Hi @JSRodz,
If you're seeing the "problem with supply system" error on your HP OfficeJet Pro 8715 after changing to new HP ink cartridges, here are some steps to troubleshoot:
Troubleshooting Steps
Check Cartridge Installation:
- Make sure the cartridges are installed correctly. Remove them and reinsert them, ensuring they click into place.
Inspect Cartridges:
- Check for any protective tape that may still be on the cartridges or any physical damage.
Reset the Printer:
- Turn off the printer, unplug it from the power source, wait for about 60 seconds, then plug it back in and turn it on.
Update Printer Firmware:
- Check for any available firmware updates using the HP Smart app or the HP website.
Run Printer Maintenance:
- From the printer's control panel, go to the settings menu and look for maintenance options to clean the printhead or align the cartridges
I hope this helps.
Please mark this post as “Accepted Solution” if the issue is resolved and if you feel this reply was helpful click “Yes”.
Rachel571
HP Support
Sneha_01- HP support
Ask the community
