Windows 11 Support Center. -
- HP Community
- Printers
- Re: Printer makes sound as though it's going to print but do...
04-20-2022 09:10 AM
my printer used to work. It was unplugged for a few weeks. When I plugged it back in, now it won't print. Yesterday it was giving me error messages. Today, it makes sound like it's going to print, but doesn't. It will even say "sent to printer" in the printer queue, then disappear. When I click a button on the printer itself, it will print a printer status report. Everything says good, that it's connected, etc. Network status - Ready, Active Connection type - Wireless. HELP!
04-24-2022 01:15 PM
Thank you for posting on the HP Support Community.
Don't worry as I'll be glad to help I understand that your HP printer is not working correctly. I appreciate your efforts to try and resolve the issue.
Please try these steps:
- With the printer turned on, disconnect the power cord from the rear of the printer and also unplug the power cord from the wall outlet.
- Remove USB cable, if present.
- Wait for 2-3 minutes, press and hold the power button on your printer for about 30 seconds to remove any additional charge.
- Now plug back the power cable straight to a wall outlet without any surge protector or an extension cord (This is important) and then plug back the power cord to the printer.
- Turn on the printer and wait till warm-up period finishes and the printer is idle.
And, aslo update the printer firmware:
- Click here to download and install the latest printer firmware from your PC.
- Click here to know different methods of updating printer firmware.
Hope this helps! Keep me posted for further assistance.
Please click “Accept as Solution” if you feel my post solved your issue, it will help others find the solution. Click the “Kudos, Thumbs Up" on the bottom right to say “Thanks” for helping!
ECHO_LAKE
I am an HP Employee
