Windows 11 Support Center. -
- HP Community
- Printers
- Re: Printer will not power up ?
05-27-2025 04:33 AM
@spencerreid5476, Welcome to HP Support Community.
I understand your HP OfficeJet 4650 printer is not powering on, and I’ll do my best to help you get it up and running again.
Here are a few steps to try:
Basic Hardware Checks
Check the Power Source:
- Ensure the power cord is securely plugged into both the printer and a working wall outlet (avoid power strips or surge protectors).
- Try a different wall outlet to rule out power issues.
Inspect the Power Cord and Adapter:
- Look for any visible damage or fraying.
- If available, try using a compatible power cord from another HP printer.
Reset the Power Module:
- Unplug the power cord from the printer and the wall.
- Wait at least 60 seconds.
- Plug it back in directly to a wall outlet and try turning the printer on.
Still Not Powering On?
If the printer still doesn’t respond:
- No lights or sounds: The power supply might be faulty.
- Lights blink briefly then go off: This could indicate a hardware failure.
If none of the above steps work, I recommend:
- Trying a different compatible power adapter if you have one.
- Or visit the nearest HP authorized service center, the service team will check and assist you.
Kindly follow this link to locate the nearest HP service center: HP® Service Center Locator - United States | HP® Support
(Select the country from the dropdown menu and enter the city name or pincode)
I hope this helps.
Please click “Accepted Solution” if you feel my post solved your issue, it will help others find the solution. Select "Yes" on the bottom left to say “Thanks” for helping!
Max3Aj
HP Support
