1
Windows 11 Support Center. -
1
- HP Community
- Printers
- Re: Printer will scan and print but will not print from comp...
06-17-2017 05:25 AM
The printer will scan and print but will print nothing from the computer; documents, pdfs off the web or pictures. I've done the diagnostics provided with the software and it tells me some issues have been fixed but it will not print the test page. It is set as the default printer. It has worked perfectly well for at least a year before that.
I have uploaded the latest Windows driver and removed the HP software and it won't print on that and won't when I reload the HP software from the HP Website. The ink supplies should be fine as the printer is not heavily used and the estimate shows at least 1/3rd black and at least 2/3rds colour. I have new cartridges but haven't tried them as it will print a scan.
Many thanks in advance. I suspect it will be something blindingly obvious except to me.
Solved! Go to Solution.
06-25-2017 03:59 PM
Hi @BrianT47,
Thank you for replying,
I appreciate your time and efforts,
As I understand you are having difficulty uninstalling the printer drivers, don't worry as I have a few steps which should help you resolve this issue.
First, unplug the USB cable from the printer if present.
· Go to Control panel – Programs and feature – Select all the HP DeskJet printer entries and uninstall them.
· Now go to Control panel – Devices and printer – Select all the printer entries and remove the device.
· Restart your computer.
· Click the bottom-left Start button on desktop, type device manager in the search box and tap Device Manager on the menu.
· Once in device manager, click on the view tab in the top & choose “Show hidden devices”.
· Then from the device manager list, check the entries under “Printer” – If there are any entries, please right click and choose “uninstall” – In the confirm device un-install pop-up, make sure you select the box which says “Delete the driver software for this device".
· Also, check the entries under "printer queue" and "imaging devices" and repeat the same exercise. Delete any printer entry or any entry which says “Unknown device”.
· Once done, close device-manger. Then press the "windows key" + "r" to get the "Run" window open - Type "printui.exe /s" and press enter.
· Under print server properties, go to drivers - remove any entry there as well.
· Again, go to run window, type – “c:/programdata” – Go to Hewlett Packard folder, remove any printer related folders & files.
· Once done you can try cleaning out your temporary files and cached files. You can try using automated applications like some cleaner software's that you can download from the internet.
· Now restart your computer again.
· Open the Run window again, type “services.msc” and press ok to get services window.
· Scroll down to “Remote Procedure Call (RPC)” – right-click and go to properties. Make sure the service is started and startup type is “Automatic”.
· Now scroll up and go to “Function Discovery Provider Host” – right-click and select properties – Change the startup type to “manual” and start the service.
· Repeat the same exercise on “Function Discovery Resource Publication” as well.
· Click on http://ftp.hp.com/pub/softlib/software12/COL48430/al-117537-4/DJ1510_188.exe and install the software.
· Connect the USB cable if prompted and follow the on-screen instructions to complete the installation.
If you are still facing the issues to remove the driver, then try using a 3rd party software removal applications like "Revo uninstaller" or "Wise" to completely remove the programs.
Let me know if those steps worked for you.
If they did, that’s awesome!
Give us some reinforcement by clicking the solution and kudos buttons,
That’ll help us and others see that we’ve got the answers!
Good Luck.
Jeet_Singh
I am an HP Employee
06-18-2017 10:39 AM
Hi @BrianT47
Welcome to the HP Forums!
Thank you for posting your query in this forum, it's a great place to find answers.
I reviewed your post and I understand that you are having issues printing from your computer.
Don’t worry, I’d love to help!
In order that I may provide you with an accurate solution, I will need a few more details.
- When you the last time the printer was working fine?
- Have you made any software or hardware changes on the computer?
- Have you performed any troubleshooting steps before posting?
Meanwhile, I recommend you to follow below steps and check if it helps.
1.) In Windows, search for and open Programs and Features
2.) Select your HP Printer
3.) Select Uninstall
4.) In Windows, search for and open Devices and Printers
5.) In the Devices and Printers windows look for your HP printer. If you see it listed right-click on it and choose 'Delete' or 'Remove Device'
6.) Open up the run command with the "Windows key + R" key combo.
7.) Type printui.exe /s and click Ok. (Note: there is a space in between “printui.exe” and “/s”)
8.) Click on the "Drivers" tab
9.) Look for HP Printer driver. If you see it Click on it and click Remove at the bottom
10.) Select Ok
11.) Select Apply and Ok on the Print Server Properties windows
12.) Close Devices and Printers
13.) Restart the PC
14.) Download and install the printer software from the below link.
15.) Connect the USB cable ONLY when prompted and follow the on screen instructions.
Let me know how it goes and you have a great day!
To simply say thanks, please click the "Thumbs Up" button to give me a Kudos to appreciate my efforts to help. If this helps, please mark this as “Accepted Solution” as it will help several others with the same issue to get it resolved without hassles.
Take care.
Cheers!
The_Fossette
I am an HP Employee
06-19-2017 04:51 AM - edited 06-19-2017 06:06 AM
Thanks for coming back but sadly it still won't work.
My last printing was a few weeks ago.
Apart from removing and re-uploading the software, I did nothing else before contacting you
I must report that the software link was not correct; it led to another printer and was rejected by the uploader. I have installed the Series 1510 one and the printer is showing correctly when a print is requested and is registered in the drivers. It just doesn't get through to the printer. I have tried another lead.
I did remove the Windows driver when going through the printer drivers installed that you mentioned. The HP driver was not shown.
I have just put the HP software on my Elite Book which I have as a spare/for trips if needed and that works fine so I have a work around at least.
06-19-2017 11:16 AM
Hi @BrianT47
Thank you for trying out the steps.
I recommend you to update the firmware of the printer and check if it helps.
Follow the steps in the below article to update the firmware.
Let me know how it goes.
To simply say thanks, please click the "Thumbs Up" button to give me a Kudos to appreciate my efforts to help. If this helps, please mark this as “Accepted Solution” as it will help several others with the same issue to get it resolved without hassles. Take care now and have a splendid week ahead.
Good day! Take care 🙂
Cheers!
The_Fossette
I am an HP Employee
06-20-2017 09:58 AM
Thank you for your response.
I cannot see any firmware updates on the HP Site for the 1512 printer. Perhaps I am looking in the wrong place. The printer works perfectly well with my spare, reconditioned EliteBook including printing AbiWord documents so whatever is wrong seems to be something not right in my desktop. I did update the Windows driver for the printer and tried printing with that without the HP driver but it worked perfectly well before when the old version and the HP driver were both there. I haven't tried with the updated Windows and HP drivers both installed.
Do you have any other thoughts?
06-20-2017 04:02 PM
Thanks for the reply,
I appreciate your time and effort.
Install the printer with the Windows Built-in Print Driver to fix this issue.
Click here and follow the steps mentioned in the document to install the printer.
Let me know if that helps.
Cheers.
Sandytechy20
I am an HP Employee
06-21-2017 09:25 AM
Thanks for the further information.
I had tried running it on the latest Windows driver alone about two replies ago and that didn't seem to work. I wasn't able to complete the steps you have just outlined for reasons not entirely clear to me. As I have a work around with my Elite Book and I don't do much printing anyway, it is a minor inconvenience but it would be good to get to the bottom of it nevertheless as it used to work perfectly well. I mention that I used the same USB port to print off the EliteBook and I have tried the lead I used for the EliteBook on the desktop.
If you can think of anything further I will give it a try.
06-22-2017 02:40 PM
Hi @BrianT47,
As I understand you have followed the steps suggested and still having the issue, don't worry as I have a few suggestions which should help you resolve this issue.
First thing, you could do here is to do a clean installation and if this does not help, I would suggest you try to create a new user account and check if that helps.
If nothing helps, I would personally suggest you contact our HP phone support so that they can remotely take control of your PC and help you check the settings.
- First, unplug the USB cable from the printer & PC.
- Click the bottom-left Start button on desktop, type device manager in the search box and tap Device Manager on the menu.
- Once in device manager, click on the view tab in the top & choose “Show hidden devices”
- Then from the device manager list, check the entries under “Printer” – If there are any entries, please right click and choose “uninstall” – In the confirm device un-install pop-up, make sure you select the box which says “Delete the driver software for this device"
- Also, check the entries under "printer queue" and "imaging devices" and repeat the same exercise. Delete any printer entry or any entry which says “Unknown device”
- Once done, close device-manger. Then press the "windows key" + "r" to get the "Run" window open - Type "printui.exe /s" and press enter.
- Under print server properties, go to drivers - remove any entry there as well.
- Again go to run window, type – “c:/programdata” – Go to Hewlett Packard folder, remove any printer related folders & files.
- Once done you can try cleaning out your temporary files and cached files. You can try using automated applications like some cleaner software's that you can download from internet.
- Now restart your computer and reinstall the printer software.
Let me know how that goes. Good luck!
If the issue persists, please try creating a New User account and then check if that helps.
If nothing works, please contact our HP phone support for available service related options.
Link to contact HP: https://support.hp.com/in-en/contact-hp
I hope this helps. Let me know how it goes for further assistance.
If you wish to help others looking for the same solution as you've found, mark the post as Accepted Solution.
If you wish to show appreciation for my effort, please click the Thumbs up icon at the bottom of my comment.
Jeet_Singh
I am an HP Employee
06-25-2017 01:40 PM
Thank you for this further help.
I couldn't see anything in the folders you mentioned that matched what you said I should delete. I do have a 'freebie' system speed up tool from Avira which I run from time to time. I can't recall if I started using it before or after the problem appeared and I have no idea whether it might have deleted something it shouldn't have or not deleted something it would have if it had been the paid version.
One thing I have noticed is that when trying to print with the printer disconnected, I just get the spinning disc which does not go away. If I connect, turn on the printer and try again, the spinning stops after a few seconds. In neither case is there any error message which you might expect to get.
I don't know if this sheds any light on the problem but I will look into the other options you mention at the end of your post if you have no further ideas.
06-25-2017 03:59 PM
Hi @BrianT47,
Good Luck.
Jeet_Singh
I am an HP Employee
Question | Author | Posted | |
06-13-2025 02:43 PM | |||
05-28-2025 02:13 PM | |||
06-07-2025 06:47 AM | |||
03-22-2024 10:48 AM | |||
06-25-2023 09:31 PM | |||
