Windows 11 Support Center. -
- HP Community
- Printers
- Re: SMART TANK PLUS 559 PRINT HEAD ERRORS
09-08-2025 10:07 AM
mY PRINTER SUDDENLY STOPED WORKING WITH BOTH PRINT HEADS SHOWING FLASHING ERRORSi HAVE CHANGED THE PRINT HEADS STILL THE SAME THE PRINTER WILL NOT RESPLND TO ANY BUTTON PUSHES, i HAVE LIFTED THE TOP AND THERE IS AIR IN THE INK TUBES THE INK TANKS ARE FULL ANY IDEAS.
BRIAN
09-10-2025 08:59 AM
@Jumbo3717, Welcome to HP Support Community,
Thank you for posting your query; I’m here to help by guiding you through steps to resolve this issue
If your printer is showing flashing errors on both printheads and is unresponsive to button presses, here are a few steps to help troubleshoot and possibly resolve the issue:
Re-seat the Printheads:
- Open the printer's top access door.
- Wait until the print carriage stops moving before proceeding.
- Carefully remove the printheads and then reinsert them into their slots securely.
Check for Air in Ink Tubes:
- Inspect the ink tubes for any air bubbles that might be causing the issue.
- You might need to perform a purge or cleaning process to remove trapped air.
Perform a Power Reset:
- Turn off the printer and unplug it from the power source.
- Wait for about 60 seconds before plugging it back in and powering it on.
Examine Ink Tanks and Lines:
- Ensure the ink tanks are properly seated and ink levels are full.
- Check all ink lines for any blockages or unusual amounts of air.
Ensure Proper Vacuum/Pressure System Function:
- If your printer uses a vacuum and pressure system, make sure it is functioning properly. Check for any leaks or blockages in the system.
I hope this helps.
Please feel free to reply here if you have any questions or if you need further clarification on any of the steps.
Did we resolve the issue? If yes, please consider marking this post as "Accepted Solution" and click "Yes" to give us a helpful vote - your feedback keeps us going!
Regards,
Garp_Senchau
I am an HP Employee
09-11-2025 06:17 AM
Hey @Jumbo3717,
Thank you for your response
I recommend contacting the nearest service center for further assistance. They will be able to diagnose the issue and advise you on the next steps.
Note: There might be a nominal charge for the service they provide.
HP® Service Center Locator - United Kingdom | HP® Support
Regards,
Garp_Senchau
I am an HP Employee
