Windows 11 Support Center. -
- HP Community
- Printers
- Re: Supply System Problem error on OfficeJet 8740
11-20-2024 08:26 AM
I'm receiving a 'Supply System Problem' error and have run a variety of troubleshooting tips - turned the printer off, updated the firmware, replaced the ink cartridges, wiped the area where the cartridges are connected, etc. What else can I do to solve this issue?
11-21-2024 02:31 PM
Hi @Lulabelled,
If you’ve already tried basic troubleshooting steps like turning the printer off, updating the firmware, replacing the ink cartridges, and cleaning the cartridge contacts, here are a few additional things you can try to resolve the "Supply System Problem" error on your HP OfficeJet 8740.
Check for Obstructions
- Open the printer's access door and carefully check for any paper jams or debris that might be obstructing the supply system.
- Look for any loose paper or small bits of paper that might have gotten stuck around the ink cartridges or printhead.
Re-seat the Ink Cartridges
- Even if you've replaced the ink cartridges, it's worth removing and re-seating them to ensure they are properly installed. Sometimes a cartridge can be slightly misaligned, which may trigger errors.
- Press down on the cartridges firmly to make sure they are securely in place.
Reset the Printer
- Perform a partial reset of the printer:
- With the printer turned on, unplug it from the power source.
- Wait for about 60 seconds to allow the printer's memory to clear.
- Plug the printer back in and turn it on.
- This can sometimes clear any lingering errors that might be stuck in the system.
Clean the Printhead
- The issue might be related to a dirty printhead, which is part of the supply system.
- Check if your printer allows you to clean the printhead manually or through the printer’s software.
- If the software suggests a cleaning cycle, perform it.
- Alternatively, carefully clean the printhead with a lint-free cloth soaked in distilled water.
Try a Different Set of Ink Cartridges
- If you haven't already, try using a different set of ink cartridges to rule out the possibility of faulty cartridges. Sometimes even new cartridges can be defective.
Check for Firmware or Software Updates
- While you mentioned updating the firmware, ensure that you’ve installed the latest version of the firmware available on HP’s website. Sometimes a more recent patch may address specific supply system errors.
- Check your printer's software for any available updates and install them if necessary.
HP Support Community Moderator
11-21-2024 02:32 PM
Run HP Print and Scan Doctor
- HP offers a Print and Scan Doctor tool that can diagnose and fix common printer issues, including supply system errors.
- Download and run the tool from HP's support site.
- Follow the instructions to let the tool check for and fix any issues with your printer.
Factory Reset
- If the error persists after all troubleshooting steps, you may want to try a factory reset as a last resort. This will erase all settings, so make sure to note down your printer settings beforehand:
- Go to the printer’s control panel.
- Find the Restore Factory Defaults option in the settings menu.
- Follow the on-screen instructions to reset the printer.
I hope this helps.
Alden4
HP Support
