Windows 11 Support Center. -
- HP Community
- Printers
- Re: Supply System Problem
06-10-2024 11:57 AM
I have been getting Supply System Problem on my printer for the past 2 weeks. I replaced the ink cartridges, unplugged, waiting the 60 seconds, plugged into a new outlet, and been on virtual chat. I was just told that the only solution as this is a hardware error is to buy a new printer. I haven't had this printer more than 3 years and of course it's out of warranty. I don't print a ton off of it either. Is there any other solution than to purchase a new printer?
06-12-2024 12:31 PM
Hi @asmith314,
I see that you are facing an issue with your printer that has a supply system problem error.
A) Please follow the steps below to perform a power drain.
1) Take out the cartridges
2) Unplug the power cord from the printer & wall.
3) Press and hold the power button down for 15 seconds and release the power button, wait for about 30 seconds.
4) Plug the power cord back into the printer and wall, ensure the printer is plugged into the wall & not into a surge protector.
5) Insert the cartridges back into the printer.
Remove the cartridges > Unplug the power cord > Wait for 30 seconds > Plug the power cord back in > Insert the cartridges
B) Kindly refer to the steps on this link to update the printer firmware and let me know if that resolves the issue.
C) If the issue still persists, refer to the steps on this link to further troubleshoot.
Please mark this post as “Accepted Solution” if the issue is resolved and if you feel this reply was helpful click “Yes”.
I hope this helps.
Take care and have a good day
Irwin6
HP Support
Irfan_06-Moderator
I am an HP Employee
