HP office jet pro 8740
HP Office Jet Pro 8740 was purchased July 2018 and was used until Dec. 2018. It was placed into storage until now. After hooking it up, the warning message was that it was out of ink. I replaced all cartridges and now get a different error message, " There is a problem with the supply system. Try replacing cartridge. If message reappears record message and contact HP".
The troubleshooting steps in the document here may help resolve the supply error message on your Officejet Pro 8740.  Before considering step 4 I would suggest the following: If the printer was unplugged before the printer had time to properly park the printheads the printhead may have dried out.  In this case, I would suggest removing the ink cartridges, then remove the printhead and soak it as described in the post here.
Bob Headrick,  HP Expert
I am not an employee of HP, I am a volunteer posting here on my own time.
If your problem is solved please click the "Accept as Solution" button
If my answer was helpful please click "Yes" to the "Was this post helpful" question.
11 REPLIES 11
@Terry109
Assuming the printer was properly stored (cleaned before storage, ink installed, upright, in a clean, cool, and dark location):
You may need to run the cleaning cycle more than once (maybe more than twice - maybe more than three times...).
Black or Color Ink Not Printing, Other Print Quality Issues
Side Bar:
The document mentions the print head assembly (M0H91A).  Parts are no longer available from HP.  I do see that eBay lists the print head assembly and Setup cartridges as a set.  Regardless of where (if) you purchase, make sure the print head assembly kit includes the Setup cartridges.
In my opinion, this is Nice printer - I do hope you can get it working again.
Reference and Resources – (More) Places to find help, solve problems, and learn how to use your Printer
Printer Homepage – “Things that are your printer”
NOTE:  Content depends on device type and Operating System
Categories:  Access to the Print and Scan Doctor (Windows), HP Drivers / Software / Firmware Updates, How-to Videos, Bulletins/Notices, Lots of How-to Documents, Troubleshooting, User Guides / Manuals, Product Information (Specifications), more
When the website support page opens, Select (as available) a Category > Topic > Subtopic
HP OfficeJet Pro 8740 All-in-One Printer series
Thank you for participating in the HP Community Forum.
We are a world community of volunteers dedicated to supporting HP technology
Dragon-Fur
Thanks, looks like Ill need to replace print head. The cleaning of print head is not allowed when current error message is up.
@Terry109
You are welcome.
OK.
Assuming you can get it, the printhead is likely not a small investment.
Before you do that - let's ask a printer hardware expert.  Smiling.
@Bob_Headrick
Any words of wisdom?
Member has an 8740 that was put into storage in 2018 - now printer does not work.
Thanks!
Dragon-Fur
@Bob_Headrick
Thank you, Bob.
I hope it works - I had a loaner Officejet Pro 8740 and I did love that printer.  Smiling.
Dragon-Fur
Thanks - I'll give it a try.
 @Terry109  - to help others who may have the same issue, could you let us know which steps actually resolved your issue?  Did you need to replace the printhead, or did soaking the printhead or some prior step resolve the issue?
Just installed new print head and set-up cartridges and now error states, "new and unused  cartridges must be used for startup". i'm missing something.
Did you get the printhead and cartridges from HP or a third party such as eBay or Amazon? What are the markings on the cartridges - do they say setup?
