The print head and cartridges are from HP. The cartridges are for set-up. After I installed new print head and set-up cartridges, the error message was " Only one set of instant ink Ready cartridges can be used in printer. Remove and replace with other cartridges". I then installed the print cartridges I purchased last week. These cartridges are from HP but I did try last week to install into the old print head. After installing these cartridges, the error message is, " Only one set of Instant ink Ready cartridges can be used in printer, Remove and replace with other cartridges". I am at a loss unless I need to purchase another complete set of ink cartridges.
Thanks for your continued help.
I have a few questions for clarification:
  • Is your printer enrolled in the Instant Ink program?
  • When you purchased the printhead and setup (Instant Ink Ready) cartridges were there any instructions on installing the printhead.  If so, were there any instructions on performing a reset for the printer?
  • Can you verify the error message does not change if you install the retail cartridges, i.e. it still complains about Instant Ink Ready cartridges?
One thing I would suggest is to remove the cartridges, then unplug the printer for a minute (without turning off the printer).  After a minute plug the printer back in, turn on the printer and install the Instant Ink Ready cartridges when prompted.
Bob Headrick,  HP Expert
I am not an employee of HP, I am a volunteer posting here on my own time.
If your problem is solved please click the "Accept as Solution" button
If my answer was helpful please click "Yes" to the "Was this post helpful" question.
