Windows 11 Support Center. -
- HP Community
- Printers
- Wireless connection
12-16-2017 05:33 PM
Hi @MartinLeibo ,
Thanks for the quick response.
I would suggest to contact HP's phone support team for further assistance.
HP Support can be reached by clicking on the following link:
* Open link: www.hp.com/contacthp/
* Enter Product number or select to auto detect
* Scroll down to "Still need help? Complete the form to select your contact options"
* Scroll down and click on HP contact options - click on Get a Case & phone number.
They will be happy to assist you immediately.
If the unit is under warranty repair services under the manufacturer's warranty will be free of charge.
Barachiel
I am an HP Employee
12-17-2017 01:06 PM
I see that you were interacting with @Barachiel. I'd like to help.
Thanks for the reply.
I appreciate your time and effort.
Yes, you can contact them when you find time.
They might have multiple options to help you on this.
Keep me posted.
Cheers.
Sandytechy20
I am an HP Employee
12-17-2017 03:18 PM
Hi and thanks for reaching out. If you have any otger slutions to try I'd like to hear them. I have now reset my IP to Auto from Manual. Rebooted router, printer and MS Surface multiple times. Uninstalled drivers and package, still fails at the same point - Installing Network.......Don't have my notes in front of me, but it's the step after after I click the option for Wireless Installation.
Odd thing is, the system sees the Printer, Router sees the Printer
Cheers
Martin
12-18-2017 01:10 PM
Thanks for the response.
Try the below steps:
- Run the HP Print and Scan Doctor.
- Temporarily disable firewall software on the computer.
- Uninstall the HP driver and software.
- Reinstall the HP software.
Click here and refer the document to perform the above steps.
Let me know how it goes.
Cheers.
Sandytechy20
I am an HP Employee
12-18-2017 11:06 PM
Problem Solved - Antivirus & Firewall - deleted the application and worked fine. Installed HP drivers and software. Re-Installed Antivirus & Firewall, set firewall rulke to allow HP and printing and scanning like advertised.
Always the virus and firewall software
12-19-2017 09:10 AM
Hi @MartinLeibo ,
Hurray!!! I'm delighted to hear that it's working! Feel free to reach out to us again. Have a great day. 🙂
Feel free to post your query for any other assistance as well,
It's been a pleasure interacting with you and I hope you have a good day ahead.
You've been great to work with and it has been a genuine pleasure interacting with you.
I hope both you and your product works great and remain healthy for a long time 😉
Barachiel
I am an HP Employee
- « Previous
- 1
- 2
- Next »
