pro 6968
I set up my printer to print grayscale and I have now unchecked this box, but it still will not print color.  Any other suggestions?
1 REPLY 1
@Kim04
Welcome to the HP Community
Is the copy working in color?
If you are facing the same issue with the copy follow the below instruction.
Try using a different ink cartridge.
I suggest you do a Hard Reset on the printer
(1) Turn the printer on, if it is not already on.
(2) Wait until the printer is idle and silent before you continue.
(3) With the printer turned on, disconnect the power cord from the rear of the printer.
(4) Unplug the power cord from the wall outlet.
(5) Wait at least 60 seconds.
(6) Plug the power cord back into the wall outlet.
NOTE: HP recommends connecting the printer power cord directly to the wall outlet.
(7) Reconnect the power cord to the rear of the printer.
(8) Turn on the printer, if it does not automatically turn on.
The printer might go through a warm-up period. The printer lights might flash, and the carriage might move.
Wait until the warm-up period finishes and your printer is idle and silent before you proceed.
Then, refer to this document: https://support.hp.com/in-en/product/hp-officejet-pro-6960-all-in-one-printer-series/8289579/model/1... for Black or Color Ink Not Printing, Other Print Quality Issues.
Keep me posted, how it goes!
If the information I've provided was helpful, give us some reinforcement by clicking the Accepted Solution and Kudos buttons, that'll help us and others see that we've got the answers!
Have a great day!
Cheers:)
Raj1788
I am an HP Employee
