Windows 11 Support Center. -
- HP Community
- Printers
- Re: my printer is making a weird noise when I go to print an...
01-03-2024 11:49 AM
My printer is making a weird noise when I go to print and then it flashes a bunch of lights and error. I got paper jam out opened all things and have taken out cartridges and put back in I can get it to rest but then when I try to print again it does same thing.
01-03-2024 12:13 PM
Printer model? Without that it is impossible to answer your question in a meaningful way.
I am a volunteer, offering my knowledge to support fellow users, I do not work for HP nor speak for HP.
01-03-2024 04:36 PM
If the carriage is just moving and slamming into the side of the printer then it is possible that you have dislodged the plastic strip that tells the printer what the current carriage position is.
