To resolve issues with 0xb90c05a4 error on your OfficeJet series: Click here to view.
My printer is making a weird noise when I go to print and then it flashes a bunch of lights and error. I got paper jam out opened all things and have taken out cartridges and put back in I can get it to rest but then when I try to print again it does same thing.
4 REPLIES 4
Printer model? Without that it is impossible to answer your question in a meaningful way.
If you find the information provided useful or solves your problems, help other users find the solution easier by marking my post as an accepted solution. Clicking "yes" on "was this reply helpful" also increases the chances that this solution will help others.
I am a volunteer, offering my knowledge to support fellow users, I do not work for HP nor speak for HP.
serial number is [personal info removed] 5SE45A HP ENVY Pro 6455 All-in-One Printer
If the carriage is just moving and slamming into the side of the printer then it is possible that you have dislodged the plastic strip that tells the printer what the current carriage position is.
It isn’t really slamming to side it never really goes to right side all the way. But that’s where it sounds like the problem is.
