To resolve issues with 0xb90c05a4 error on your OfficeJet series: Click here to view.
HP OfficeJet Pro 9015e All-in-One Printer
my printer will not print, diagnose and fix shows no errors, print jobs sitting in queue
1 REPLY 1
Hi @KM051,
I understand you're experiencing an issue with your printer that is not printing.
I apologize for any inconvenience this may have caused, I'm here to help you today.
Are you able to make a copy on the printer standalone? (Place an original document on the scanner glass and make a copy to confirm hardware is working fine)
Click on this link to clear the jobs stuck in print queue: https://support.hp.com/in-en/document/ish_2026148-1648338-16
New follow the steps below to fix the issue.
A) Perform a power drain.
1) Take out the cartridges
2) Unplug the power cord from the printer & wall.
3) Press and hold the power button down for 15 seconds and release the power button, wait for about 30 seconds.
4) Plug the power cord back into the printer and wall, ensure the printer is plugged into the wall & not into a surge protector.
5) Insert the cartridges back into the printer.
Remove the cartridges > Unplug the power cord > Wait for 30 seconds > Plug the power cord back in > Insert the cartridges
B) Kindly refer to the steps on this link to update the printer firmware and let me know if that resolves the issue.
C) If the issue still persists, uninstall the printer software by following the steps from this link and restart the devices.
D) Install the printer software by clicking on the link again and let me know if that resolves the issue.
Note: Enable Bluetooth for an HP Smart app setup: Enable Bluetooth on your computer or mobile device so that HP Smart can detect the printer during the setup.
Please mark this post as “Accepted Solution” if the issue is resolved and if you feel this reply was helpful click “Yes”.
I hope this helps.
Take care and have a good day
Irwin6
HP Support
Irfan_06-Moderator
I am an HP Employee
