Windows 11 Support Center. -
- HP Community
- Printers
- Re: Printer will not connect to wireless Network
01-03-2018 08:30 AM
I am having issues with my printer and connecting to my wireless network. This printer has been installed and working for months and then suddenly it will not connect to the wireless network.
I have not changed routers or settings, the printer did work for 6 months or so on this network.
I have attempted factory resets, etc. to get this working with no luck. The wireless network test results show a No Filtering Fail
I have checked my router and MAC address setting is set to allow all.
Any help would be greatly apprectiated.
Thanks,
01-04-2018 01:49 PM - edited 01-04-2018 02:08 PM
Hi @TSmith88,
Welcome to the HP Forums!
This is a wonderful place to converse with the community, get assistance and find tips.
I reviewed your post and understand that the printer is not connecting to your wireless network.
I'll be glad to help you 🙂
In order that I may provide you with an accurate solution, I will need a few more details.
- When was the last time the printer was working fine?
- Have you made any software or hardware changes on the computer?
Meanwhile, I recommend you follow the steps in the below article and check if it helps.
Please post your results, as I will be looking forward to hearing from you.
To simply say thanks, please click the "Thumbs Up" button to give me a Kudos to appreciate my efforts to help. If this helps, please mark this as “Accepted Solution” as it will help several others with the same issue to get it resolved without hassles.
Good day! Take care 🙂
Cheers!
The_Fossette
I am an HP Employee
01-05-2018 09:17 AM
Hi @TSmith88,
Thank you for the information.
Follow the steps in the below article and check if it helps.
Good day! Take care
Cheers!
The_Fossette
I am an HP Employee
01-08-2018 10:40 AM - edited 01-08-2018 10:41 AM
I have attempted this the HP Print and Scan Doctor again in attempts to fix. This did not work. My printer will still not connect to the wireless netowork that it had previously been connected to.
I still get an error everytime I attempt a connection and when I print the error page it shows the same message
>Settings
- Printer Settings Consistent with Wireless Router Settings PASS
- No Filtering FAIL
- Channel Not Run
- Security PASS
01-09-2018 08:20 AM
Hi @TSmith88,
Is the printer connected to the network? Check the wireless light. If the light is steady blue, then the printer is connected to the network. If the light is flashing, then the printer is not connected to the network. Go to Setup - Network - Wireless setup wizard to connect the printer to the network.
Once the printer is connected to the network, then assign a static IP to the printer:
Obtain the IP address of the printer – You can touch the “wireless” icon on the printer control panel to get the IP address.
Type the IP address on your web browser to obtain the printer EWS page on your computer.
Go to "Network" tab - General - Select "Network protocols" - Select "Enable IPv4 only" (or similar) - Apply the settings.
Go to the “Network” tab – Click on “Wireless (802.11) – Then click on “Network address (IPv4)
Click on the radio button which says “Manual IP” and then click “Suggest a manual IP address” to give a manual IP address to your printer.
Click on radio button which says “Manual DNS Server” and under manual preferred type 8.8.8.8 and under manual alternate type 8.8.4.4 (This is Google DNS server address)
Now, try the steps below to install the printer over the network:
First, unplug the USB cable from the printer if present.
Go to Control panel – Programs and feature – Select all the HP Officejet printer entries and uninstall them.
Now go to Control panel – Devices and printer – Select all the printer entries and remove the device.
Restart your computer.
Open the Run window (Press Windows logo key + R), type “services.msc” and press ok to get services window.
Scroll down to “Remote Procedure Call (RPC)” – right-click and go to properties. Make sure the service is started and startup type is “Automatic”.
Now scroll up and go to “Function Discovery Provider Host” – right-click and select properties – Change the startup type to “manual” and start the service.
Repeat the same exercise on “Function Discovery Resource Publication” as well.
Click on http://hp.care/2ptjjHb and install the software.
Select Wireless option on the connection page and then finish the installation.
Let me know how it goes and you have a great day!
Take care.
Cheers!
The_Fossette
I am an HP Employee
01-09-2018 09:25 AM
While I appreciate the level of detail in your response, it does not address the key issue as stated in my intial subject line.
It seems that no matter what I do, I cannot get my printer to connect to my wireless network. It was previously connected to this same network. It detects that it is there. It attempts to connect. But everytime it fails. When the report is printed it states that it is a No Filtering Fail.
I have attempted to add the MAC address into my router and turned MAC filtering on... no connection. I have left the MAC address in the router and turned MAC filtering off... no connection.
This my entire issue.
Thanks,
01-09-2018 10:58 AM
Hi @TSmith88,
I am sending you a private message with instructions. Please perform the steps to reset the printer.
Please check your private message icon in the upper right corner of your HP Forums profile.
Next, to your profile name, you should see a little blue envelope, please click on it.
Let me know how it works and you have a good day ahead.
The_Fossette
I am an HP Employee
10-09-2018 11:51 AM
Thanks for posting in the support forums. I have reviewed the post.
I will send you a private message to assist you with the next course of action. Check your forum private message box in the upper right corner next to the bell icon.
Thanks for visiting the HP support forums.
DavidSMP
I am an HP Employee
