HP Smart Tank Plus 570 Wireless All-in-One
I've tried resetting the printer by disconnecting power and waiting 60 seconds, but the printer goes through a restart attempt but crashes (after the cartridges move a little) with error code 0XC4EB8004 HW_MICCI2_V12.
Have you any help with what I can try now ?  Thanks
@RJL15041912, Welcome to HP Support Community.
The 0XC4EB8004 HW_MICCI2_V12 error on the HP Smart Tank Plus 570 usually indicates a hardware failure, often related to the ink system, printhead, or internal electronics. Here are some steps to try:
Power Reset (Deep Reset)
Since you've already done a basic power reset, try a deeper reset:
>Turn off the printer.
>Disconnect the power cable from both the wall and printer.
>Remove all cartridges.
>Hold the Power button for 30 seconds.
>Plug the printer directly into the wall (avoid surge protectors).
>Turn it on without reinstalling the cartridges yet.
>If it starts without the error, reinstall the cartridges one by one.
Check for Paper Jams or Obstructions
>Open the ink access door and remove the cartridges.
>Inspect the printhead area and carriage path for any stuck paper, debris, or ink spills.
>Move the carriage gently left and right to check if it moves freely.
>If you see ink buildup, use a lint-free cloth slightly dampened with distilled water to clean it.
Clean the Encoder Strip
>The encoder strip is a clear plastic strip behind the carriage. If dirty, it can cause errors:
>Locate the clear strip behind the printhead carriage.
>Gently wipe it with a soft, lint-free cloth dampened with filtered water.
>Let it dry before turning the printer back on.
 Reseat the Printhead
>If your printer has a removable printhead:
>Open the ink door.
>Lift the printhead latch and remove the printhead.
>Clean the contacts with a lint-free cloth.
>Reinstall the printhead, close the latch, and restart the printer.
Update Firmware (If Possible)
>If the printer works intermittently before showing the error:
>Download and install the latest firmware from HP’s website:
HP Support - Software & Drivers
Try a Semi-Full Reset (Factory Reset)
>Press and hold the Power button.
>While holding, press the Cancel button 5 times, then Resume button 2 times.
>Release all buttons and wait for the reset process.
I hope this helps.
Max3Aj
HP Support
3 REPLIES 3
>Open the ink door.
I hope this helps.
Max3Aj
HP Support
Thanks Max3Aj,  It's working now
@RJL15041912, A huge thank you for marking this post as the 'Accepted Solution'! We're thrilled that we could help resolve your issue.
If you have any more questions or need further assistance, please don't hesitate to ask. We're here to help!
Thanks again for your confirmation, and we wish you an amazing day ahead!
Regards,
Max3Aj
