Windows 11 Support Center. -
- HP Community
- Printers
- Re: my printer says door is open but it's not and it won't p...
02-25-2019 05:32 PM
error message on printer: door is not closed
Solved! Go to Solution.
02-27-2019 09:49 AM
Welcome to HP Support Community,
Did you close the cartridge door completely?
Have you checked the cartridge door for obstructions?
Did you reset the printer?
Step one: Close the cartridge door completely
If the cartridge door is not completely closed, the error message displays.
Open, and then close the cartridge door of the product. Make sure that the door rests securely against the body of the product.
Figure : Examples of closing the cartridge door (your product might vary)
NOTE:
To see how to close the cartridge door of your specific model, see the cartridge section of your product's User Guide.
Check the product control panel to see if the error message still displays.
If these steps resolved the issue, there is no need to continue troubleshooting.
If the issue persists, see the next step.
Step two: Check the cartridge door for obstructions
Inspect the door and the area around it to make sure that no obstructions prevent the door from closing completely.
NOTE:
Bits of paper, packing materials, and tape might prevent the door from closing completely.
Remove any obstructions.
Step three: Reset the product
Press the Power button (
) to turn on the product. -
Disconnect the USB cable from the back of the product.
CLICK HERE FOR MORE STEPS AND INSTRUCTIONS.
Let me know how it goes!
Jeet_Singh
I am an HP Employee
02-27-2019 09:49 AM
NOTE:
NOTE:
Jeet_Singh
I am an HP Employee
02-28-2019 02:06 PM
I'm glad you got this issue sorted out.
Do visit our HP Forums and drop us a message anytime you need help.
Thank you 😀
Jeet_Singh
I am an HP Employee
08-21-2019 01:44 PM
Do you also have the HP 6830? If yes, this could be a hardware issue. Recommend you to contact the HP Support Team.
Link: https://support.hp.com/us-en/contact-hp?openCLC=true
Note: Select the country accordingly to get the contact details for support.
If no, please let us know the Printer name.
If the information I've provided was helpful, give us some reinforcement by clicking the Accepted Solution button, that'll help us and others see that we've got the answers!
Thanks!
I am an HP Employee
