1
Windows 11 Support Center. -
1
- HP Community
- Printers
- Re: power button not working after auto shutdown. power & wi...
10-10-2020 07:09 AM
I have a new HP Officejet 9015 printer. After the printer does an auto shutdown the lights on the front for power and wireless remain on and the power button will not turn on the printer. The only way to turn on the printer is to unplug it and then plug it back in. I don't think this should be necessary. Any suggestions to fix this annoying issue would be appreciated. Thanks.
Solved! Go to Solution.
10-14-2020 06:23 AM
Yes, since this is new, I would recommend that.
If the information I've provided was helpful, give us some reinforcement by clicking the Accepted Solution and Kudos buttons, that'll help us and others see that we've got the answers!
Thanks!
Have a great day!
I am an HP Employee
10-12-2020 09:24 AM
Let's try a firmware update: https://support.hp.com/in-en/document/c02919168
Also, try the steps from here: https://support.hp.com/in-en/document/c06199701
Let me know if this helps.
Thanks!
Have a great day!
I am an HP Employee
10-13-2020 08:23 AM
Thank you for your reply. We have already downloaded the latest firmware (the printer already had the latest) and extensively tried every possible solution found on the HP site and beyond. We are now feeling that this could be a hardware issue and will likely return the printer to Staples.ca and then perhaps order another one of the same model from them. Your thoughts? Thanks.
10-14-2020 06:23 AM
Thanks!
Have a great day!
I am an HP Employee
