To resolve issues with error EBS00P0013 on HP Smart App: Click here to view.
HP officejet 9015
I have a new HP Officejet 9015 printer. After the printer does an auto shutdown the lights on the front for power and wireless remain on and the power button will not turn on the printer. The only way to turn on the printer is to unplug it and then plug it back in. I don't think this should be necessary.  Any suggestions to fix this annoying issue would be appreciated. Thanks.
Yes, since this is new, I would recommend that.
If the information I've provided was helpful, give us some reinforcement by clicking the Accepted Solution and Kudos buttons, that'll help us and others see that we've got the answers!
Thanks!
Have a great day!
I am an HP Employee
5 REPLIES 5
@BH8686
Let's try a firmware update: https://support.hp.com/in-en/document/c02919168
Also, try the steps from here: https://support.hp.com/in-en/document/c06199701
Let me know if this helps.
Thanks!
Have a great day!
I am an HP Employee
Thank you for your reply. We have already downloaded the latest firmware (the printer already had the latest) and extensively tried every possible solution found on the HP site and beyond. We are now feeling that this could be a hardware issue and will likely return the printer to Staples.ca and then perhaps order another one of the same model from them. Your thoughts? Thanks.
Thanks!
Have a great day!
I am an HP Employee
Thank you for taking a look at the problem I was having. I did replace the printer and the new one is working perfectly.
@BH8686
Glad to know that the issue is now resolved by replacing the printer. Feel free to contact us with any concerns related to HP products.
Happy to help!
KUMAR0307
I am an HP Employee
